cookie 1.8 16 valver
Fuel Lines VAG only ?
You can just se regular 8mm fuel hose from any motor factors but for the moulded (shaped) hoses I would stick with VAG.
Sorry - just read that it's a 16V - if you mean the metal braided pipes then it's probably VAG only unless you know of someone local that can make them up to size...
The braided lines are stainless, so don't rust. They were later changed to metal and rubber hose to reduce costs, maybe he has these?
but the crimped steel ends do rust quite a lot.
Thanks guys, it is a 91 1.8 16 Valver and has just the standard metal pipes, as you say think it's going to be a sand and hammerite job to ensure they dont rust anymore.
Hope everyone had a great bank holiday, fab weather to get stuff done for a change !
