billinjah
interior sill cover clips
im talking about the plastic clips that hold the sill trim on they push into0the floor and also hold the carpet in place. i ordered some new from vag, but when they came they are a different type they are too small for the hole in the floor is there another piece that clips into the floor? the part number is correct and tallies with ekta i assume they have changed the design at some point but i cant see how they are going to fit.
Yep the new clips are a different design to the original. They should come with separate inserts that plug into the sill panel, than the plastic cover clips push into the inserts. I might have the numbers somewhere, but the dealer should know this.
Ah good man Chris.... I got a load of the smaller ones too but not the inserts! Assuming they were wrong I then went back and they then got me the older style ones though?
Found em at last. The numbers you want are:
"Sill Clip" 191853615A - these fit on to the plastic cover strip and then push into the
"Grommet" 191853586D - these push into the holes in the sill panel.
Obvious when you see them
HTH
