Rawhide
Audi TT On ebay.. Gearbox Blowup!
Yep, 02Js throw the diff pins through the casing too.....and that's precisely where the hole is...adjacent to the diff.
It's been a known issue since the 020 box (MK2 Golf) and VAG are too tight to use bolts instead of rivets on the diff crown wheel.
It's usually load related.....the harder you drive it, the stronger the likelihood of a diff pin letting go. I'm only aware of half a dozen instances, so it's not THAT common a problem.
Bad story.. but the chap is being rather negetive about VAG. All manufactures have there problems.
Look at his favourite for example - BMW with mini! I remember hearing the odd story about them catching fire!
mine went bang on my valver..........
Not heard of them going on cable change corrado 16V box's though.....
