rado-steve
Help Please???? How do You remove Rear Bench and door Cards?
Think i'm being thick, in my MK2 the were some screws hiding under little plastic clips.....On the C Nowt!!!!
Also guess you can take the rear door card off after taking out the bench???
Help Guys
Steve
if i'm recalling correctly, you can just pull the bottom part of the seat out to give you better access to the panel. but, with a little jiggering you can pull the panel out with it in situ. screw at the bottom, one near the top where the seatbelt threads through and one at the back.
hth
randal
the bottom part of the seat is held in by a metal hook,to remove you need to push the bottom art of the seat towards the rear of the car and lift at the same time
The rear bench can be abit of a tricky b****r but as dazzyvr6 says push towards rear and pull as hard as possible upwards!!! :)
