chimo 0 Posted July 18, 2005 Dispite what people say, swapping door cards and getting your window switches to work is NOT A PLUG AND PLAY situation. about a month ago I searched and found the thread that I wanted, a thread that said which color wire goes to what post. I simply cannopt find that thread. After searching on and off for about 3.5 hours I'm ready to tear my hair out (and it's receeding anyway :( ) Can anyone shed light onto this? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 18, 2005 No it's not plug and play - there is a list in the knowledge base but there is not enough information there to really help, I'm planning to do the conversion using the later loom.... Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted July 18, 2005 If you can bear with me, I can dig out the wiring list I made up when I converted JMC's doors from early to late switches... I'll hunt tonight, and will PM you if I find anything. Steve, would this want to go on the knowledge base if I find it? Jonathan's switches all worked first time when I did them... Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 18, 2005 Yep, that would be great dude! Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted July 18, 2005 Converting early Corrado electric window switches to late-spec Driver’s Door Early wire colour---->goes to---->Late wire colour Green---->White (Pin 5) Grey/Black---->Grey (Pin 3) Grey/Red---->Grey/Red (Pin 4) Black/Blue---->Grey/Blue (Pin 6) Brown/White---->Brown (Pin 1) Green/Yellow---->Green/Yellow (Pin 2) Passenger’s Door Early wire colour---->goes to---->Late wire colour Green/Yellow---->Blue/Yellow (Pin 5) Grey/Black---->Grey (Pin 3) Grey/Red---->Grey/Red (Pin 4) Black/Blue---->Grey/Blue (Pin 6) Brown/White---->Brown (Pin 1) IIRC, that's how I did JMC's - if any of the wiring colours are different to what you have, please let me know and I'll correct it...! I used Passat connectors for his, but I'm guessing the late-spec 'rado ones will use the same wire colours. NOTE: All of the interconnecting wires between the two switches in the driver's door are discarded - you only need the six incoming wires. Quote Share this post Link to post Share on other sites
randal 0 Posted July 18, 2005 Unless you have after market VAG-esque windows like some poor soul I know... :roll: Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted July 19, 2005 i have a pair of later door looms with later style window & mirror connections/wires=£14 posted to uk Quote Share this post Link to post Share on other sites
dinkus 10 Posted July 19, 2005 You might need to give him a price for postage to Canada bigpants baby ;) Quote Share this post Link to post Share on other sites
JMC 0 Posted July 22, 2005 Having recently installed a late style interior to my G60 I can definately concur - it wasn't just plug and play. GradeAFailure was a great help in going my electric window switches (and yes they did work first time :) ). You also need to source some late style interior door handles as the early ones are the wrong shape for the cut out in the late door cards. These are a direct replacement and are easy to swap. And then there is the electric mirror control that needs changing (waiting for the right socket so I can do mine at the moment). Then that should be it - good luck!! Quote Share this post Link to post Share on other sites
