g60greeny
too much to weld
my car recently failed its mot on a few bits and bobs one which was excessive corrosion to one of the sills at first it didn't look to bad,but after a closer investigation its quite bad :shock: it could do with a complete sill(better off doing it proper)does anyone know where i could get one from? and any idea how much?cheers
depending on how bad it is,you could just take it to a body shop,they will then just cut the rotten bit out and weld a plate in there,if its done proporly you would never tell,painting it afterwards wont cost much either
true,i've got to get my passenger side arch sorted out so i suppose i could get them sprayed at the same time,i think i've seen the sills on eurocar parts site for 30 odd quid not including vat,my mate says there a place in sheffield called autorad that deals with panels i'll give them a ring after work tomorrow couldn't see anything on there web site
