JOHN.JARMAN2
VR6 wont start
Vr6 starts then die's after about 2 sec's. It also cut out recently whilst i was driving it.
I have been told it could be the fuel sensor or the coil pack, i be very greatfull for any help.
Thanks
If it starts fine then dies just after then it sounds like it's probably something to do with the immobiliser.
Have a search and see what pops up ;)
What age is the VR? If it has a factory immobiliser, then what he /\ says....
Otherwise have a look at the VAG-COM and scanning help page to see if anyone's near you to help out.
Don't make the same mistake I did.
Had the same symptoms, spending at least a couple of hours checking all the usual culprits without stopping to check the blindingly obvious.
Turned out to that the ignition barrel was springing back past its normal running position because it was old and worn out. :)
Mate had a simlair problem with his VR6.. he had several bits replaced.. never foundout what was the problem.. its gone in to OEM to have heart surgery now!!
