R1-Jay
Headlight question
Probably a really simple question, i should be getting my C within the week but it has a broken drivers headlight. As its a 1990 G plate, is it a new headlight or a replacement lens?
Replacement lenses can be had for around £30 from GPC or ECP.
It might look a bit odd if you just replace one though, as it will be much cleaner and clearer than the old one.
I replaced just one headlight after a front end crunch in my 1990 Corrado 18 months ago. If you were looking closely you could see the difference but, ultimately, it looked fine.
Yeah, it depends on how old and battered your current lenses are, but you can certainly just replace the glass.
Edit: Oh and apparently the early-shape lenses are cheaper than £30! :)
