stooby doo
Steering Wheel Judder under braking at high speed
Hi guys,
I've noticed that under braking from speed, i.e. coming off the motorway onto the slip road, my steering wheel is juddering a lot.
It doesn't have to be heavy braking - pedal to the floor - it is apparent under gentle braking, but always from speed.
I was thinking it could be warped discs but would it not judder all the time, braking at low speed, if that was the case ?
Any ideas what else it could be ?
I have this intermitently! I have new WBs, full alignment just done and wheels balanced and its done it on 3 diff sets of wheels. I am as usual perplexed
I would imagine warped discs for sure.
I know for a fact mine are warped slightly and I have the same issue.
At low speed it is not as noticable as hard breaking from speed mind.
Dutch
i recently had a problem where the brakes where juddering when braking from high speed but wasnt really noticeable at lower speeds, it turned out to be a badly cracked disk
I guess at warped discs too tbh... my freind had the same with his volvo T5
Good luck getting it sorted
