Roger Blassberg
Poor pick-up from closed throttle
Since the VR was sitting around for 2 weeks whilst I was away, it seems that the pick up from closed throttle to small opening has become ragged. The idle is also a bit irregular and surges a little, more than it used to, and often very nearly stalls. Trickling through traffic is marked by lurching from closed to open throttle.
It sounds like TPS trouble - am I on the right track here?
What are the solutions? Presumably a new TPS ultimately, or is a Basic Settings the first step? Or both? I haven't disconnected the battery or anything to upset the ECU
(And compared to the TDI which I hired on holiday, the low revs torque is poo !!)
Best wishes
RB
ISV?
How did the battery not die after two weeks of inactivity, anyway?? Mine is usually pancake-like after a fortnight..
How do you clean the ISV? Where abouts is it in the engine? I started having similar problems today.
Cheers
Stan
A good squirt with some brake cleaner. I follow that with some WD. Hunt around the air pipes that bypass the TB.
Gavin
  Roger Blassberg said:
A set of new NGK plugs and a quick clean of the ISV, and we're back to normal.
Best wishes
RB
did you reset the ECU?
  Quote
No, it didn't seem necessary. It is now running very smoothly; this morning is cold and damp and the performance is especially good.
Incidentally, I bought the NGK plugs from http://www.sparkplugs.co.uk a terrific service. They were on my doorstep 18 hours after I ordered them on the net. 6 plugs for about £23 including delivery.
Best wishes
RB
OK, as Im home in deepest darkest Wales :) I dont have a manual to hand. Which is the ISV? Sorry for being a dunce :(
It's on the middle back of the engine under the back engine cover between the secondary water pump on the nearside corner back and the throttle body on the off-side. Thick stubbly thing with two rubber air hoses and one electrical connection.
