Turbogirlie
Which oil?
dr_mat, generally speaking, yes.
I'm not sure on exactly what happens, but once you get over the listed max temperature you start breaking down the oil and chemically change it so that it doesn't work as well. If you do it enough then you permenantly change the oil and need to change it.
A lot of oils will withstand over 120degC but for how long and that's the point.
The oil will shear with heat (lose viscosity) and therefore does not afford the same protection.
Cheap oils and mineral based oils are more prone to severe shearing due to heat because they are less thermally stable than proper synthetics.
Race oils and similar top quality ones simply last longer because they are more thermally stable to begin with, uniform molecules and less polymers to work as a multigrade.
Have a read of this and you will get some idea of what constitutes a good oil.
Why do oils lose viscosity with use?
Viscosity Index Improvers.
An oils viscosity will decrease as the engine temperature rises. Viscosity Index Improvers are added to reduce this thinning. They are a key addative in the production of multigrade oils.
VI Improvers are heat sensitive long chain, high molecular weight polymers that minimise the viscosity loss of the oil at high temperatures. They work like springs, coiled at low temperatures and uncoiling at high temperatures. This makes the molecules larger (at high temps) which increases internal resistance within the thinning oil. They in effect "fight back" against the viscosity loss in the oil.
"Shearing"
The long chain molecules in VI Improvers are prone to "shearing" with use which reduces their ability to prevent the oil from losing viscosity. This "shearing" occurs when shear stress ruptures the long chain molecules and converts them to shorter, lower weight molecules. The shorter, lower weight molecules offer less resistance to flow and their ability to maintain viscosity is reduced.
This shearing not only reduces the viscosity of the oil but can cause piston ring sticking (due to deposits), increased oil consumption and increased engine wear.
Like basestock quality, VI Improvers also vary in quality. As with many items the more you pay, the better the finished article and more expensive, usually synthetic oils are likely to incorporate better VI improvers. All other things being equal the less VI improver an oil contains, the better it will stay in grade by resisting viscosity loss.
Which oils require more VI Improvers?
There are two scenarios where large amounts of these polymers are required as a rule.
Firstly in "wide viscosity span" multigrades. By this I mean that the difference between the lower "W" number and the higher number is large for example 5w-50 (diff 45) and 10w-60 (diff 50) are what is termed as "wide viscosity span" oils.
Narrow viscosity oils like 0w-30 (diff 30) or 5w-40 (diff 35) require far less VI Improvers and therefore are less prone to "shearing".
Secondly, mineral and hydrocracked (petroleum synthetic oils) require more VI Improvers than proper PAO/Ester (Group IV or V) synthetic oils as they have a higher inherent VI to begin with, this is due to differences in the molecular structure of the synthetic base oils compared to mineral oils.
It is a fact that many synthetics require significantly less VI Improver to work as a multigrade and are therefore less prone to viscosty loss by shearing.
So, is Quantum Silver good?
For a stock road car, why not, it won't be stressed!
For a heavily modded track car, forget it. Look for a proper race oil.
Cheers
Simon
Degradation of the oil due to shearing is a one-way process though, and therefore pushing your car temp high will have a negative impact on oil performance, but that negative impact cannot be recovered by cooling the engine down again...
And the shearing tends to reduce the oil viscosity, according to the above, so the losses inside the engine due to oil friction would actually be reduced.
Yup, but presumably if you don't do it for too long, you won't have sheared all the oil, so most of it will still be good.
Yup, but it won't lubricate properly - it'd be like putting water in there (ok ok it wouldn't because it wouldn't corrode like water, but you get the idea).
Synta Silver is perfectly good enough for a standardish road car provided you change it regularly.
If you're tuning the engine to within a gnats testicle of death, then driving it hard on a track then sure - get fully synth.
Completely agree, I'm happy with Synta Silver in mine, it doesn't get *that* thrashed .. :)
And the oil temp doesn't get over 115 or so, even with sustained motorway driving. (Even though I didn't see the point of a third party oil cooler..)
