trev-b 0 Posted September 7, 2005 Hey guys its time to change the rear tyres on my C (205/40/16 on 16x 9" wheels) and i'm having difficulty getting the same brand (federal). I couldn't find any info in the search so thought i'd try here. Does anyone know of any other makers tyre which fit those size rims or will i simply have to go up a size? Yokohama Paradas don't fit by the way as i tried them today. Quote Share this post Link to post Share on other sites
Grim 0 Posted September 16, 2005 Hey Trev, 205/40 R16....on 16x9" rims.....i'd recommend against that personally. You'd generally need a tyre with a larger section width to suit that rim. Going by the ETRTO (effectively the bible to the tyre and rim rim industry), you should really try 225/40 R16, but even then you may struggle to find anything. If you'd like, give me the front tyre size, and i'll do some calculations and suggest a replacement size. You'd probably notice an improvement on handling too. Ian Quote Share this post Link to post Share on other sites
redcorrado 0 Posted September 16, 2005 lol i was running 195/50 /15 on my 9x15 split rims. Quote Share this post Link to post Share on other sites
Grim 0 Posted September 16, 2005 Ouch. have you changed the tyre size now? Quote Share this post Link to post Share on other sites
bix 0 Posted September 16, 2005 I think you prolly want 205/45/16s on a corrado, 205/40/16 is actually smaller than the stock tyres! Quote Share this post Link to post Share on other sites
Grim 0 Posted September 16, 2005 depends on the rim measurements to be honest Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 16, 2005 205/40/16 tyres fit perfectly imo and no rubbing.... give http://www.styledynamix.com a call and see if they can send you some Quote Share this post Link to post Share on other sites
redcorrado 0 Posted September 16, 2005 Ouch. have you changed the tyre size now? yes sold them a while ago Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted September 16, 2005 FurkiG60, he need 16" tyres :) Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 16, 2005 dazzyvr6, edited jus for you buddy 215/35/16 would also look really mean on a 16x9 rim but costs a lot more too Quote Share this post Link to post Share on other sites
Polo Classic 0 Posted September 17, 2005 215/35-16 is not aproved by dunlop on anything wider than 8-16. No tyre manufacturer accepts less than 215/40 on 9-16, it is not safe Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 17, 2005 Polo Classic, looks soo good and ive seen them running on alot of cars and they do work........if you run the proper size for a 16x9 rim it would most likely or definately foul on the arches Quote Share this post Link to post Share on other sites
billinjah 0 Posted September 17, 2005 we shouldnt really run tyres this narrow on rims this wide but hey we shouldnt do a lot of things!!! Quote Share this post Link to post Share on other sites
Bobby 0 Posted September 18, 2005 i've seen 195/45/16's used on a 9*16 rim before, have used 205/40/16 on the same rims for years and never had a problem Quote Share this post Link to post Share on other sites
Furkz 0 Posted September 18, 2005 ive seen 195/40/16 on 16x9's and that going too far seriously NOT recommended Quote Share this post Link to post Share on other sites
Grim 0 Posted September 19, 2005 Ok, try 225/40 R16. This is probably the smallest/closest tyre size that would be recommended for fitment to a 16x9 rim. :brickwall: Quote Share this post Link to post Share on other sites
mk1-corrado 0 Posted September 19, 2005 i run 215/40 R16's on my 9x16 Borbet's, but rolled arches before i stopped Panel beating, so she don't rub now!!! Quote Share this post Link to post Share on other sites
trev-b 0 Posted October 4, 2005 Thanks for the advice guys, 225s would be far too wide unfortunatly as the 205s catch the arch and they've been cut back (pretty low though). I ended up getting 205/45/16 Federal 595s which fill the wheel a lot more than the 40 profiles. Federals seem to be one of the only tires to accept such a stretch owing to their large rim protectors. Will post photos asap. Quote Share this post Link to post Share on other sites
