Stan 24v
Resistor pack blown!!!
when i did this to the resistor pack on my passat b3, (same part looking at the pictures) i used some of that nylon covered screw-in terminal strip stuff. i cut away the nylon covering so i was left with just the brass inner, arranged the thermal fuse and wires from the old fuse and tightened up the screws- saves potentially blowing the new fuse and is much easier to replace if it goes again :)
