-Neil-
New LIGHTING done! *PAGE 5*...
like you said too much for my car, but what a stunning job neil!! very impressive indeed and more than showable! bit it sounds awsome too.
how/where you get those pods dude?
Im selling my install, two 10" subs and set of 8" 4 way speakers, 2 amps, one 2 channel mono amp for subs and a 4 channel for speakers and my sub boxes.
Im asking £600 for the lot!
Baring in mind the boxes cost me over £200 in matrials and time to make.
The primer/paint/laquer cost £80 alone!
To see how i made this install please see bottom of this thred..
For more info contact mailto:sheffield_raver@hotmail.com
Neil
Info below..
4 Channel amp:-
4 channel Amplifier
Continuous power @ 4 ohm: 50W x 4
Continuous power @ 2 ohm: 75W x 4
Max Power Rating: 600 watts
S/N Ratio: 90 dB:
Freq. Response: 20-20KHz +/- 1dB
Damping Factor: > 50
Input Sens. : 200mV - 4V
Crossover type/range/slope: Variable HP/LP, 50-250Hz, 12dB/octave
Bass EQ: Switched, +6/+12dB @ 50Hz
Protection: Thermal, Short circuit, Reverse polarity, Status LED
Mono block amp:-
Features:
High-speed MOSFET power supplies
Complimentary bipolar transistor outputs
Built-in 2-way variable crossovers (2 channel & 4 channel models)
+6 or +12 dB switchable bass boost
RCA input with adjustable gain
Power/status LED
Heavy duty screw terminals accept up to 8 AWG cables
High level inputs with auto turn-on
10" subs:-
Product Features
10" Directed Xtreme subwoofer
Magnet: 40 oz.
Power Handling: 200 watts RMS/400 peak
Impedance/voice coils: dual 4 ohm v.c.
Freq. Resp.: 25-2500Hz
Efficiency: 86dB (1W/1M)
Depth: 4-1/2"
4 way speakers:-
4 way quadrax system 200watts max powers.
Nickle plated steel basket
Long life rubber surround
basket type for universal mounting possibilities
Magnat protection
Wires and protection grills included.
How i made the install....
i started with a base to which the stretchy matirial would be attatched to.
then i made some rings for the speakers to be atacthed to and for the material to stretch around, they are on stilts which will be removed at a later date, their just to hold the rings in place...
then i put the stretchy material on and pinned it into place, then soaked it in firbegalss resin mixed with hardener....and left it for about 48 hours to dry properly
this is an inside shot with the stilt removed, you can see how smooth it is...
then i got some fibre glass matting and placed it on and used a paint brush to put the resin on...(USE GLOVES, it goes everywhere!)
Then leave that for about 48 hours or more, then i put Easy Sand body filler on to give it strength and also to make it easy to smooth, i ended up with about 1cm of filler all the way around,
I then chopped it in half and set about making it fit my boot, i removed the base i made at the begining (as it was made for my old car) and then firbe glassed the pod to this base i made for my corrado boot....
I then got a board for the back for the amp, and did a little more sanding, still quite a way to go tho! I also put it in to see how it sounded, it sounds GREAT!
I then Set about spending about 20 hours finishing it, this is after the sanding and with grey primer, i SHOULD of used 'filler primer' but i didnt so i had to do alot of sanding, spraying, sanding, spraying etc...
then i used the CORRECT primer for the pearlessant paint i was using, this was a filler primer which helped!
This is the colour i chose, pearlessant Rover trophy blue found on MG's.
I then set about spraying, leaving about 30 minutes between coats, i had 2 heat lamps on them from above which helped.
I then laqured them, about 4 cans worth, i wanted the to be REAL shiny!
Then laqure you HAVE to put on it thin coats, this took about a week to do, 2 hours every night leaving 30 mins between each coat WITH heat lamps on them...
then put them in my car, oh how shiny!
and i also made myself a parcell shelf to mount my mirror onto...
and i also set my second amp onto the floor, one amp for subs, other for my in-car speakers and the REAR speakers, i can unplug the REAR speakers so i only have the on for show perposes etc, no point having them on whilest im in the car...
then i put a floressent light in....
and to what it is now.....
Love it, looks really good!
Prefer the red in the middle for sure, but that's jsut me and my red light fixation... (working in Kings X at the moment...) 8)
  -Neil- said:
Before anyone posts any comments like, how horrible, i know that not everone will like what i've done, but it's kept me busy and i enjoyed making it.
And that's the main thing :wink:
Not my bag but appreciate the work that's gone into it 8)
