timmaaah
Measuring my voltage drop
Hello everybody - I'm prolly gonna uprate my headlight loom - but I'm a bit confused with regarding measering the voltage before and after. I'm not a div, but I can't for the life of me work out where to take my readings from. Do take it I take a reading direct off the battery, and compare it to a reading taken from the connectors on the bulb's + and -? I think I had too much beer last night, and I'm just confusing myself!! Any pointers would be really helpful - cheers!
You put 1 probe on the positive battery terminal, and the other on the bulb positive terminal, but that will only give you the volt drop in the positive wire, there will also be volt drop in the negative! So simply measur the voltage at the bulb and subtract it from the voltage at the battery! :)
EDIT: as you say 8)
Were are you gonna get te uprated loom from? Gav, H100VW, does te best ones, and is highly recommended by all here wo have one. I have one, and its tops!!
