Dutch24V
Replacing the heater matrix this weekend
One thing though, as the monkeys at my local VW dealer don't know - will a new matrix from VW have the valve in it to stop coolant p*ssing all over my floor when it fails, or do I have to buy this valve seperately??
Dutch
has it got a 'B' suffix on the part number?
If it has, then it's got the valves built in... 8) If it's for a VR6 then it should have the valves in it anyway though... 8)
Apparently the C matrix is now the same part as a golf 4 matrix? - which I presume has the valve built in.
I will check the part number tonight to be sure though.
Cheers...
ah, your car will be LHD then seeing as you're in Holland? In that case, I have no idea, sorry... :|
Saysomestuff: That's my thinking too, but just wanted to be sure.
Henny: Do you think there'll be a difference then between RHD & LHD? I don't see why?
Will check part number anyhow later tonight...
yeah, The parts ARE different for LHD and RHD... the pipes come out of the matrix and through the bulkhead at a different angle. :roll:
