jonny-5 0 Posted September 22, 2005 Could someone just tell me how to get the needle off the speedo gauge, does it just pull off? Quote Share this post Link to post Share on other sites
chrishill 0 Posted September 22, 2005 yes hth ;) Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted September 22, 2005 Yup - easiest way is to slide a fork underneath the needle and pull straight upwards. If you pull at an angle, you risk bending the shaft that the needle fits on. It does take a lot of force, but that's normal. I'd also advise lifting the needle over the stop before you remove it, and seeing where it comes to rest, otherwise you'll end up putting it back in the wrong position (just like I did - you know, I really should sort that out...) :) Quote Share this post Link to post Share on other sites
olly elworthy 0 Posted September 22, 2005 lever off with two teaspoons,,, :thumbleft: Quote Share this post Link to post Share on other sites
jonny-5 0 Posted September 22, 2005 The fork trick works a treat Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted September 22, 2005 I like a chainsaw, it works best for me........oh sorry were we talking about the speedo? needle nose pliers Quote Share this post Link to post Share on other sites
