task
mk2 16v clutch fit G60?
02A 16V and VR6 IIRC. Basically, the 020 gearbox in the MK2 is rod change and use the 'reverse' flywheel method, i.e. the pressure plate bolts to the crank and the flywheel attaches to the pressure plate.
The 02A box (all Corrado, cable change) is the other way round....flywheel bolts to the crank.
The VR6 genuine VW clutch is the best to use on a G60 as it can take 300hp all day long, so gives you plenty of scope for tuning.
task, what do you actually need??
If its a G60 then get either a G60 clutch or a VR6 clutch...
(the VR one is cheaper and better)
