bristolbaron 11 Posted October 16, 2005 did you manage to drive it home? how did it drive? Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 16, 2005 Yea I drove it hone, its not jerky lik before but its lacking serious power. Really stinks of oil inside too, but it's filled up. Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 16, 2005 i had the head gasket done on my 8v..cost £200. Best of luck dude. Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 16, 2005 Ok so say if it was the head What sypmptons would there be and would it be "ok" to drive Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 16, 2005 normally one sure fire way to tell a head gaskets gone is there will be a mixing of oil and water in the engine this creates a mayonaisse-like goo thats thick on the oil filler cap(tho a small amount could just be condensation which isn't a major prob btw) there should also be a large amount of white smoke coming from the exhaust your water level will constantly need topping up oil and water will be mixing in the coolant tank.......tho again this can sometimes just be down to the oil cooler needing replaced poor performance can also be a sign of head gasket failure as for driving it..............i would get it in a garage for a diagnosis ASAP...........and would leave driving it to a very bare minimum......otherwise you'll more than likely need the head skimmed and could even sieze the engine if it gets too hot Quote Share this post Link to post Share on other sites
bix 0 Posted October 16, 2005 normally one sure fire way to tell a head gaskets gone is there will be a mixing of oil and water in the engine this creates a mayonaisse-like goo thats thick on the oil filler cap(tho a small amount could just be condensation which isn't a major prob btw) there should also be a large amount of white smoke coming from the exhaust your water level will constantly need topping up oil and water will be mixing in the coolant tank.......tho again this can sometimes just be down to the oil cooler needing replaced poor performance can also be a sign of head gasket failure as for driving it..............i would get it in a garage for a diagnosis ASAP...........and would leave driving it to a very bare minimum......otherwise you'll more than likely need the head skimmed and could even sieze the engine if it gets too hot You say oil will be in the water, and vice-versa, which isnt true, I've had a head gasket blow between 2 cylinders, oil was leaking out of the head, but there was no water or oil contamination! Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted October 16, 2005 what was in the fuel can before you filled it up with petrol??? was it damp with condensation or was it open in the garrage and full of spiders? if it was damp, could explain the lack of drive and jerkyness. if it was spiders could be blocked fuel filter. Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 16, 2005 TBH It couldve been open but I never really looked into it, as fas as i knew there was nothing in it. My mum told me arlier last time she put in she use a little bit of water to mix it up :lol: Couldve been a spider in there as there are loads in the shed Quote Share this post Link to post Share on other sites
ZippyVR6 0 Posted October 16, 2005 well like these guys say I would sort out the fuel filter and fingers crossd for ya chap. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 16, 2005 You say oil will be in the water, and vice-versa, which isnt true, I've had a head gasket blow between 2 cylinders, oil was leaking out of the head, but there was no water or oil contamination! but it is true as this can also happen...........i didn't claim that it was an exhaustive list of possible head gasket symptoms and i didn't say that these would all happen together :roll: ..........eg his oil could easily be mixing with the water yet he might not be getting the white smoke from the exhaust Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 16, 2005 Well I had to fill up just now and took the car To my suprise its flying, i didnt attemp to go fast but it did, But im still very wary of what went wrong so im not gonna leave it alone. Quote Share this post Link to post Share on other sites
mistrall 0 Posted October 17, 2005 morning - (tv is playing up again lol) when mine had these sort of probs she would fly 1 min and then loose power mabe 4 miles down the road - or not at all on one journey but on the next lol so if it does this - change the fuel filter (im guessing it doesnt have a cat) just thought i would mention it incase lol - but as the guys say there are many posibilities Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 17, 2005 Ok Ill try and change the fuel filter then. Is there any guides anywhere to help me change it? Quote Share this post Link to post Share on other sites
bix 0 Posted October 17, 2005 Ok Ill try and change the fuel filter then. Is there any guides anywhere to help me change it? Simple job, just dont smoke while your doing it! Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 17, 2005 lol I hate smoking so Ill be fine Just have no idea how to do it Quote Share this post Link to post Share on other sites
Henny 0 Posted October 17, 2005 Just have no idea how to do it You could start by looking in the "exterior" part of the Knowledge base... ;) Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 17, 2005 Oooh yea forgot bout that! Seems hidden that part lol Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 20, 2005 I just took the car for a drive now, and still no change. It really really judders like it's missing and when in 5th at 30mph it feels like it's going to stall. Got a feeling it could be the backbox I put on, like I havn't put it on properly because I remember the last backbox went and snapped and it had the same symptoms of this now so I'm gonna give that a check later. I havn't had the time or the money to get a new fuel filter either. Gonna need my car running for Saturday because of the Karting in Herts. Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 20, 2005 Another thing, when it's idle, and I hit the accelerator it's really jerk and choke. Gotta feeling it is the fuel filter Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 20, 2005 http://the-corrado.net/.archive/forum/viewtopic.php?t=31497 Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 20, 2005 Mines a KR aint it? ( :oops: ) Quote Share this post Link to post Share on other sites
vr6storm 0 Posted October 20, 2005 Mines a KR aint it? ( :oops: ) yip :D Quote Share this post Link to post Share on other sites
veeDuB_Rado 0 Posted October 20, 2005 Wel I think me ( Actually my dad) has sorted the problem there was oil in the distibutor and when we cleaned it out good and proper th car seems to be running fine. well im gonna go get a new fuel filter anyway Thanks for the help guys, i wouldnt have survived! Quote Share this post Link to post Share on other sites
