badlad1888 0 Posted October 19, 2005 To get my lights to sit perfect, can you just adjust the lights or is it the the hatch needing reseated so the lights sit straight? Its a poor picture but you can see the inside lights sit wrong. :cry: Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 19, 2005 are they aftermarket lights? Quote Share this post Link to post Share on other sites
badlad1888 0 Posted October 19, 2005 no just the original lights tinted. Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 19, 2005 you can adjust the inside lights a bit,the aftermarket lights are worse than that,you need to enlarge the holes to get more adjustment with them Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted October 19, 2005 adjust the lights. both sets have some degree of movement. take the plastic over off the inside of the boot lid and you will see nuts that can be loosened to allow movement of the light blocks. On the square sections each side has a nut hidden under the rubber grommet . 8mm socket I believe Quote Share this post Link to post Share on other sites
badlad1888 0 Posted October 19, 2005 cheers guys, will give that a bash tomorrow. its been pissing me off for weeks now! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 19, 2005 Also there are some rubber 'stops's for the tailgate that can be adjusted by turning... Quote Share this post Link to post Share on other sites
RW1 0 Posted October 19, 2005 Supercharged, if the rubber stops were "high" on the hatch outer area's the boot wouldn't lock I think or would be very, very hard to get it to lock as the hatches's catch mechanism wouldn't reach to close the lockfinger home. Need a side profile shot in line with the rear lamp face to see the body lines alignment. I did wonder whether the boot catch on the back panel had slipped upwards. It's hard in that shot to make out whether the body lines are correct. The hatch and rear body appear OK suggesting the inner lamps aren't seated fully home. . Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted October 19, 2005 Mines like this too - cant remember if the lights were level before I got the car painted! :? I'll try adjusting them from behind the trim panel as you guys have suggested :D Quote Share this post Link to post Share on other sites
RW1 0 Posted October 19, 2005 Joeblogssvr69. That looks like the hatch is not aligned, not the lights. Need to wind in the two rubber stops and see how it sits. Still high? Then adjust the square looking boot catch to sit further down in the rear panel on the opposite side to the central VW badge on the outside (Need to use an impact drive to undo / tighten the two philipd screw head type bolts. When sitting right. Then adjust outwards the two rubber stops on the hatch to kill the vibration rattle of the lock & square catch. . Quote Share this post Link to post Share on other sites
