Bobby 0 Posted May 22, 2006 I just out the leak on mine was the the inlet seal on the air intake , the seal was only a couple of quid and no more wet carpets.I took the whole carpet which i would advise as the sound proof padding needs to be dried out properly as it acts like a sponge and holds water for a long time. Plus i changed the carpets to black ones from grey,as the grey ones are too hard to keep clean. Its not hard to take the full carpet out. Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted May 22, 2006 I did the same on my valver -sorted in no probs! Quote Share this post Link to post Share on other sites
lottysvdub 0 Posted May 23, 2006 check your rear light seals , mine had split causing water to weep in under heavy rain it then tracked through the car and started to make the rear footwells fill with water :) Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted May 24, 2006 Found how the water is getting into the car, as illustrated in the image. My problem now is figuring out how much of the dash I need to take to bits to get underneath that particluar panel. Any suggestions? Quote Share this post Link to post Share on other sites
lottysvdub 0 Posted May 25, 2006 if its comming in through there , i would suggest new door appature seal and strip the door trim off and check the door drain holes as if they block up they will flood your car but also check the door membrain ( plastic sheet over door ) for holes or tears because this is whats supposed to stop any moisture or water comming in from your doors :) Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted May 25, 2006 cheers ian, will take the door card of again, never had it of the passenger side, so might reveal somthing Quote Share this post Link to post Share on other sites
RADO.001 0 Posted May 25, 2006 well ive only got one a damp footwell but its the drivers side. its not soaking throught the carpet so you can see but you can feel its wet! so what do you think it could be, drivers door seal? help please Quote Share this post Link to post Share on other sites
davedub 0 Posted May 25, 2006 the flood of posts on this subject (excuse the pun) is indicative of the monsoon conditions we've had recently and its reasonable to expect leaks here and there on 15 year old cars. At the end of the day its not the worst thing that can happen and theres the rest of the summer :oops: to dry out. Agree with posts regarding clearing drainage holes etc and something as simple as facing your car the other way when parking can work wonders! Quote Share this post Link to post Share on other sites
RADO.001 0 Posted May 25, 2006 davedub said: facing your car the other way when parking can work wonders! wont FIXS the problem tho will it m8 :roll: Quote Share this post Link to post Share on other sites
davedub 0 Posted May 25, 2006 Quote wont FIXS the problem tho will it m8 _________________ dont knock it till you've tried it. Can only speak from my own experience and its worked for me. the angle at which rain hits your car can make all the difference. just trying to help. Quote Share this post Link to post Share on other sites
lottysvdub 0 Posted May 25, 2006 RADO.001 as ive said mate check the door drain seals and membrain on that side , check the door seal for damage or flat spots , failing that lean across the seats with the doors closed an get someone to spray water over the suspect area and look for water tracking inwards , hope this is some help :) Quote Share this post Link to post Share on other sites
