Stan 24v
Headlight beam too high
Is there any guidance on how high the headlight beam should be, without taking it to a garage? My passanger side is a bit high (I think) and was just wondering how high it should be?
Ta 8)
Park up against a wall at night, level ground, the horizontal part of the beam shouldn't be above the middle of the light(ish).
Gavin
After lowering my C I noticed that the beam seems to be too high. Because the arse isn't in the air anymore it has changed the angle of the beam. Been meaning to adjust it for ages.
There is a big white adjuster on the top of each headlight, that moves the beam up and down. The drivers side one is hidden by a plastic cover, the passenger one can be done without any tools.
Gavin
