Critical_Mass 10 Posted October 28, 2005 Hello, I have got an eyebrow to fit, but what it the best way to fit it. I have 2 eyebrows one with out any holes drilled into it and the other with a number of holes drilled into it along the top. How have others fitted them? Help would be appreciated. cheers guys Quote Share this post Link to post Share on other sites
chrishill 0 Posted October 28, 2005 what sort of eyebrow is it mate? eyebrow/grille or just the brow? people recomend screwing them into the headlamp plastic at either end, but the one I had on my 16v was stuck on with loads of gooy stuff and wasnt going anywhere! Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 28, 2005 Its just the eyebrow. If i glue it on will it effect the lights as in, if i ever needed to get the headlights out? Cheers Quote Share this post Link to post Share on other sites
edd 0 Posted October 28, 2005 I used the double sided tape from halfords works fine on mine and can be easily removed if need be Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 28, 2005 is that the same stuff as the trim tape. if so ive got some of that knocking around! Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 28, 2005 yeah...ive got that stuff and i'd say it would do the trick. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 28, 2005 yeah well i stuck a rub strip back on my car with it and its still holding on firml. Ill give it a go. PLUS if nec you can take it back off Quote Share this post Link to post Share on other sites
