billinjah
gsf accel cables?
How easy is it to fit? Mine's got a crack in it near the TB and I'm starting to feel resitance at the peddle :(
Yeah.. its a doddle Phil. You do have to arse around in the footwell but should be able to do the whole job in about 20-25 minutes all in.
if it needs doing replace the rubber grommit that the cable attaches through on the accel pedal.
This is likely to be worn and causes extra stress on the metal hook, increasing wear. its about 50p too!
Lippy
