G60Jet
Air Fuel Ratio Meter
I got my Air fuel ratio meter today from the states, looks mint
anyway
As you know it needs to be wired into the o2 sensor.
So what i want to know is where can i pick up the wires from the o2 sensor closer to the ECU rather than fitting them under the car at the decat pipe?
The 02 plug is on the rear engine mount. You could always tap into it there and then run the wires through a grommet on the bulk head?
Kev
you should ground the gauge to the same ground as the o2 sensor, behind the engine.
