cymru-corrado 0 Posted November 29, 2005 as in title really will a 16" wheel with 45 offset fit ok without spacers. had a look on a site with offsets and the corrado was specified as being able to use 35-43 offset so unsure on 45. anyone know if these will go on ok? Quote Share this post Link to post Share on other sites
Chris VR6nos 0 Posted November 29, 2005 don't know but the higher the offset thte more you may need to use spacers to reduce the problems of fouling the strut Chris Quote Share this post Link to post Share on other sites
KarlG60 0 Posted November 29, 2005 can I nip in your post? I've seen some amazing rims heres the details... Front : 8J x 16 et 25 Rears : 9J x 16 et 14 Would they be able to fit on the rado?! don't mind about arch flare just need advice!! Thanks! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted November 29, 2005 ET 45 OK on the VR6 with it's 10mm longer wishbones, but on the 16V/G60, you'll more than likely foul the inner arch on full lock. Stick to ET35 or use 10mm spacers on your ET45s. Quote Share this post Link to post Share on other sites
