scarlett
koni adjustables - how do i?
morning all!!!
quick question - hopefully with a quick and easy answer!!!
new valver has Konigsports at the front and height and ride adjustable Koni springs at the back.... prob is the back currently sits higher than the front and needs levelled out... am refusing to raise the front so i need to find out how to lower the backs and what i need to do it....
any ideas how to do this? am gonna try and contact previous owner to get more info on exactly what set up it is....
cheers! :)
havent the koni top adjustable rear shocks got a circlip with 5 settings for height??
no idea how to change them though
Ar if it is those you can take the compression away from the spring then remove the circlip and replace in a lower groove..
what happened to the rear konigsports ?
