jonny-5
My horn doesn't work
What is says really, i've checked all the fuses, connections and earths but still nothing. My biggest clue is that when you press the horn you get a clicking noise from behind the fuse box, almost like a relay. Also the radiator fan doesn't seem to work any more and as there on the same fuse do you think it's connected??
Can anyone please help??
1 Headlight, low beam, left 10
2 Headlight, low beam, right 10
3 Instrument panel lights, license plate lights 10
4 Rear window wiper 15
5 Wiper/washer, front 15
6 Fresh air fan 20
7 Tail lights, side marker light, right 10
8 Tail lights, side marker light, left 10
9 Rear window defogger 20
10 Foglights 15
11 Headlight, high beam, left 10
12 Headlight, high beam, right 10
13 Horn, radiator fan run-on 10
14 Back-up lights, washer jet heaters 10
15 Electronic ignition, idle stabilizer, deceleration fuel shut off 10
16 Dash warning lights, glove box light, cassette storage light, rear spoiler adjustment control unit 15
17 Emergency flasher switch, turn signals 10
18 Fuel pump 20
19 Radiator coolant fan, A/C 30
20 Brake lights 10
21 Interior lights, cigarette lighter, digital clock,
rear spoiler adjustment 15
22 Radio 10
fuse No 13 , maybe check it again or swop it with 12
have you got dual horns ?
get someone to press it (ignition on) and check there for the voltage, if theres nothing
then do the same and check at the fuse
mine did that,but it was the contact on my actuall wheel which needed adjustin,i also checked the fuses an even unpluged the actual horn and cleaned the connectors
Consider yourself lucky.... mines always on unless I disconnect the horns :lol:
Gonna take off the stearing wheel this weekend and look at the connections.
I've got a healthy 12 volts at each terminal, so i tried taking the horns apart but they're pretty much sealed units, so i got a nice set from halfrauds for about 10 quid, that'll do
look under the battery to see if any wires have worn through. is the fuse good as the horn relay is before the fuse in the circuit.
Just tried the new horns and...........nothing, this is doing my head in, what's going on???!!! All the fuses and relays are fine and i have 12 volts all the way to the connections for the horn it's self. All i can think of is that the horns i brought aren't designed to relplace a factory twin horn setup like a corrado, cos they come with a relay and stuff.
Hmmm....
Depends what you got, Halfords do a pack of 2 red horns which work well as a direct replacement altho they plugs are different so you have to re-terminate.
Yeh i got the twin pack one maded by a company called 'ring'. They just have two spade connectors on each horn that i just plugged in to the existing connectors. I treid swapping all the connections as well, but still no luck, i'll have another bash tomorrow though
Sorted the bugger. The horn "loom" (if you can call it that - it's only about four wires!) had a dodgy bit of wire on it that had worn through and was occasionally earthing onto the body of the car.
