Not_Aircooled_or_Taxfree 0 Posted February 2, 2006 Hello! Both of my rear wheel bearings have decided to die on me (3-4mm travel through the wheel and alot of noise) so I am off to get some more from GSF. But before I do I am wondering about the fact that BOTH bearings have gone at the same time, is it symptomatic of another problem? And would this problem ruin the new bearings in a short period of time? I was told to look at the rear break callipers (thanks Yanards) to see if they were binding, but is this all I should be checking or is there something else like evil dwarfs or bad spirits that could be the problem? I have run a search but nothing has been said about simultaneous bearing failure. Ta! PS Is it only the wheel bearing kit I need to do the job and are there any special tools needed?Hello! Both of my rear wheel bearings have decided to die on me (3-4mm travel through the wheel and alot of noise) so I am off to get some more from GSF. But before I do I am wondering about the fact that BOTH bearings have gone at the same time, is it symptomatic of another problem? And would this problem ruin the new bearings in a short period of time? I was told to look at the rear break callipers (thanks Yanards) to see if they were binding, but is this all I should be checking or is there something else like evil dwarfs or bad spirits that could be the problem? I have run a search but nothing has been said about simultaneous bearing failure. Ta! PS Is it only the wheel bearing kit I need to do the job and are there any special tools needed? Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 2, 2006 Not_Aircooled_or_Taxfree said: Hello! Both of my rear wheel bearings have decided to die on me (3-4mm travel through the wheel and alot of noise) so I am off to get some more from GSF. But before I do I am wondering about the fact that BOTH bearings have gone at the same time, is it symptomatic of another problem? And would this problem ruin the new bearings in a short period of time? I was told to look at the rear break callipers (thanks Yanards) to see if they were binding, but is this all I should be checking or is there something else like evil dwarfs or bad spirits that could be the problem? I have run a search but nothing has been said about simultaneous bearing failure. Ta! PS Is it only the wheel bearing kit I need to do the job and are there any special tools needed? just need a small punch to knock the old races out, use the old race to tap the new ones in, providing the wheels spin freely with the handbrake off I can't see they have overheated from binding brakes, perhaps they were both badly adjusted? You will need a caliper wind back tool though most likely, I'd personally replace the rear disks while I'm at it. Oh, you will need grease and a couple of split pins. David. Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted February 2, 2006 Cheers dude! Of to GSF now Quote Share this post Link to post Share on other sites
Supercharged 2 Posted February 2, 2006 Make sure you get the SFK ones, not the cheap Jap rubbish... Quote Share this post Link to post Share on other sites
2cc 0 Posted February 2, 2006 AND you need to get the carriers off to remove the disc. They have 4 recessed hex head bolts so you will need a spline drive on a socket T bar to get them out; 8mm IIRC. Actually I would buy some new ones to put back in as they are prone to damage when you (or previous owner/garage) take em off Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted February 2, 2006 Do GSF sell both the SFK and the Jap ones then...? My rear bearings are being done at The Phirm tomorrow (simply cos it's too cold for me to be bothered!) and they'll be sourcing the bearings for me, and I suspect they'll come from the ubiquitous GSF seeing as they're right by one... Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 2, 2006 I got the cheap GSF ones last time and they've lasted 8 months, had put it down to my poor fitting of them....but maybe it wasn't all my fault. Gone for the more expensive ones now, £9.90 each as opposed to £6something. BTW, if you mention you are a member of the corrado club (no proof required) when on the phone, you get a 10% discount! So that brings the bearings in at £8.91 each. :lol: Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted February 3, 2006 Doing the job now and i am wondering what grease to use! I have some high temp grease Castrol MS3 will that be ok or do i need to get some LM grease? Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted February 3, 2006 Help me please, its cold and snowing (a bit) and i wanna put my car back together! Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 3, 2006 Not_Aircooled_or_Taxfree said: Help me please, its cold and snowing (a bit) and i wanna put my car back together! CV joint high temp grease is fine. David. Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted February 3, 2006 thank you!!!!!!!!!!!!!!!!!!!!!!!!! Huggs and kisses! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 3, 2006 Supercharged said: Make sure you get the SFK ones, not the cheap Jap rubbish... You mean the £6.50 'VTECH' ones? They're what's in mine at the moment :-) I dumped my warped rear discs (cheap VAG rubbish ;-) ) and fitted Pagid FRs and Brembos to match the fronts.....and tbh I looked at the bearings closely and they're fine.... £90 for both Brembos, set of MK4 FRs and 2 bearing kits.... can't really grumble at that :-) Not fried or Barbequed, use LM grease mate, it's designed for wheel bearings, graphite CV grease isn't! Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 3, 2006 Agreed, LM grease all the way. What does LM stand for by the way? Low melting? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 3, 2006 High melting point LithiuM apparently.... You want the grease to melt anyway so that it goes to a smooth oily consistency, hence why you have the rear rubber seal and front cap to stop it leaking out ;-) If the grease stayed highly viscous, it would cause too much drag and the bearings would run dry..... but you don't want it to get too hot too quickly..... Quote Share this post Link to post Share on other sites
Not_Aircooled_or_Taxfree 0 Posted February 4, 2006 I have broken one of the sliding bolts on the carriers. GSF dont seem to sell them or they are not listed as carriers. Anyone have any advise or better a spare one? ..............stupid rusty thing........................ Quote Share this post Link to post Share on other sites
kebabman 0 Posted February 4, 2006 Get a new one from VW, I got a whole bag of them from a VW commercial vehicle centre for next to nothing. Is worth having spares for all 4 as those bolts are very prone to snapping when rusty. Quote Share this post Link to post Share on other sites
