matth76
How to remove light scratches - which products to use?
Hi I have some scratches on my golf vr6 which are very light but spread over a large area and on different areas of the car. I suspect they have come from a bit of grit in the sponge or chamois when the car was washed.
I'm going to give T-cut a go but in my experience T-cut doesn't seem to do anything on my VR with its lacquered paint work. I've thought about paint compound but (although being much harsher than T-cut) I am pretty sure it won't make any head way on lacquered paint either.
Does anyone know some good cheap reliable scratch repair companies in Sussex area that you have used and were very impressed with the end result and value for money?
Or can anyone recommend any products (will a polish of some kind work?) to try that won't damage my paint work, but work really well to remove scratches..as I'd rather try it myself that pay someone to do it? However I need to know which product to try that will likely work, and which products I should definitely avoid.
Matt
