cheesy
Front top mounts
is there any difference from the 1.8 top mounts to the vr6 ones.
are they stiffer? would they fit the 1.8 ok?
Do 1.8s have 1 peice top mounts like the MK2 Golf? VR6 mounts will go on anyway and are much stronger than MK2 mounts. You need to order the bearing and the rubber donut as they are seperate items. You may also need the VR6 top plates. I fitted some VR ones to one of my MK2 Golfs no problem, so you shouldn't have any problems on your valver.
Yes they are a bit stiffer but you won't feel it through the column.
Kev
If you're going to change the mounts than upgrade to the later style (they were available on the later 2.0 16v and VR6).
The doc attached shows exaclty what you need, everything on the later stlye page.
HTH
