leew 0 Posted January 30, 2003 Anybody know how to solve squeeky brakes? I have drilled disc on the front (where the squeel is coming from). The squeel starts after the brakes warm up a bit. Is it the old 'copper grease on the back of the pads' solution or could it be something else? Quote Share this post Link to post Share on other sites
Sandy 0 Posted January 30, 2003 What pads are you using had this problem when I was using EBC pads !! Quote Share this post Link to post Share on other sites
leew 0 Posted January 30, 2003 Don't know. They were on the car when I bought it. Quote Share this post Link to post Share on other sites
kevin 0 Posted January 31, 2003 i replaced my front pads from genuine vw to pagid pads approx 6 months ago and the left front pad has sqeeked ever since ,the only cure seems to be to take the pads out give them a light sanding, that sorts it out but only temporaliy,even tried new calipers and that hasent stoped it,could it be the vented and grooved disks or shit pads :mad: Quote Share this post Link to post Share on other sites
Banana Man 0 Posted January 31, 2003 The cause will be the compound of the pads themself the only pads I ve found that dont squeek are ferrodo unfortunately I replaced mine with motaquip pads and know I regret it as theyn squeek as well it's bloomin annoying isn't it!!! Quote Share this post Link to post Share on other sites
leew 0 Posted January 31, 2003 It's not exactly the way I wanted to get people to notice the car!!! :oops: Quote Share this post Link to post Share on other sites
Jim 1 Posted January 31, 2003 Well.. worth mentioning that I have pagid 8 groove discs and pagid fast road pads on the front. Can't say I have ever had squeeking under braking, and they have been on the car over a year. Quote Share this post Link to post Share on other sites
G60 0 Posted January 31, 2003 stock pads.. mine don't squeek! :roll: try the copper grease. might do the trick.. Quote Share this post Link to post Share on other sites
Jim 1 Posted January 31, 2003 Can also help if you (and excuse me if this is the wrong term as I genuinely dont know) de-fuzz the edges of the brake discs with a grinder. A friend of mine was getting sqeaking from one of his discs - took the wheel off, went round the edge of the disc blasting the fuzz off, problem solved. No more noise. Again - could be totally unrelated but.. never know :| Quote Share this post Link to post Share on other sites
VR6 0 Posted January 31, 2003 Can also help if you (and excuse me if this is the wrong term as I genuinely dont know) de-fuzz the edges of the brake discs with a grinder. A friend of mine was getting sqeaking from one of his discs - took the wheel off, went round the edge of the disc blasting the fuzz off, problem solved. No more noise. Again - could be totally unrelated but.. never know :| Jim - presume you mean the lip that forms at the edge of the disc? Spose the easiest way, if you have the tools, is a lathe and machine the edge off. Or as Jim says, de-fuzz it :lol: ........ Sorry mate :D Quote Share this post Link to post Share on other sites
Nik Patel 0 Posted February 3, 2003 theres probably not enough copper grease on the back of the brakes also sometimes u just need to refit the brakes woked for me Quote Share this post Link to post Share on other sites
