BlackHeartValentine 0 Posted April 10, 2006 Can Anyone Tell Me Why My MFA says MPG 99.9? The Time Clock on it is right, Oil temp works, It's just the MPG says 99.9! :( Quote Share this post Link to post Share on other sites
W3RKD 0 Posted April 10, 2006 i would say you vac hose may of become disconected from the clocks.. 99.9 is the default mpg if i remember correctly Quote Share this post Link to post Share on other sites
BlackHeartValentine 0 Posted April 10, 2006 Where can I find this vac hose? Would I have to go digging in the dash or is it under the hood? Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted April 10, 2006 As Darren said - it plugs into the back of the clocks on a G60. So probably the best place to start ;) Quote Share this post Link to post Share on other sites
BlackHeartValentine 0 Posted April 10, 2006 Do you have a link for a walkthrough/how to on removing the clocks? Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted April 10, 2006 There's a Search you know ;) http://the-corrado.net/.archive/forum/viewtopic. ... 2711#92711 Quote Share this post Link to post Share on other sites
s.g 0 Posted April 10, 2006 i can remember reading about this in a vw mag i will try and dig it out Quote Share this post Link to post Share on other sites
BlackHeartValentine 0 Posted April 10, 2006 Thanks For Your Halp! ;) Quote Share this post Link to post Share on other sites
s.g 0 Posted April 10, 2006 right had a look in the mags and found the article in volkswagen driver. it says it could be due to a faulty speed/hall sender. the hall sender can be checked with a multimeter. one turn of the wheel should produce four voltage jumps from 0v to 5v. i hope this helps you Quote Share this post Link to post Share on other sites
selbekk 0 Posted April 10, 2006 mine shows 0.0 l/100km.. what would that be caused by? Quote Share this post Link to post Share on other sites
dinkus 10 Posted April 10, 2006 mine shows 0.0 l/100km.. what would that be caused by? Sounds like it's the same problem, just different measurement units. Quote Share this post Link to post Share on other sites
s.g 0 Posted April 10, 2006 something unpluged if it showing 0.0 i would have thought, have u checked back of clocks Quote Share this post Link to post Share on other sites
s.g 0 Posted April 10, 2006 or what dinkus says, it worth checking Quote Share this post Link to post Share on other sites
dinkus 10 Posted April 10, 2006 Ohhh ok 0.0 litres/km - I read it as 0.01/km Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted April 11, 2006 Either that or the right hand peadl is welded to the floor :lol: (99.9 MPG) Quote Share this post Link to post Share on other sites
selbekk 0 Posted April 12, 2006 well, it kind of goes up to 0.1 or 0.3 liters per 100 km every once in a while. I think the back of the clocks is fine. Quote Share this post Link to post Share on other sites
