BlackHeartValentine
WEIRD NOISE!! Help
Well, I was on my way to work going bout 75 mph on the highway and it was early so I cut the rear defroster on cause of due on my back window...about a minute later the DASH Starts Screaming at me!! WAaaaaahhhhhhhh!! It sounded like it was coming from behind the clocks!! It wasn't coming from the engine but from somewheres inside the dash!! What the hell would make it do that? It stopped as soon as I slowed down to 3rd gear. HALP!
Sounds like the oil pressure warning buzzer to me too.
Check your oil pressure is ok before driving any further. Was the oil pressure warning light flashing on the dash?
Ferenheight not celcius, the water temp gauge on my car starts at 130 next number on it is 230...the oil temp reading I get is from the MFA...Does that sound high? :(
Also, It didn't do it again after it stopped, I drove another 23 miles after that and everything seemed fine, I know my coolant level is a bit low right now too though.
And my oil light has come on before but it made a beeping noise this was a screaching noise like when you let the air out of a ballon while pinching the sides to make it looud hahaha, know what I'm saying.
My water temp usually sits around 90 degC, and oil at 106 degC.
I would want to confirm the oil pressure is ok if it was my car. Other than the oil pressure warning buzzer I cannot think of anything else which would make a loud noise behind the instruments.
Yeah, that's where mine sits, smack dab in the middle inbetween 160 and 230 on the middle marker...funny thing is, the sound only comes on if I turn on my rear defrost button! It never comes on otherwise...phantom buzzer!!
I missed that in the 1st post! Got to be a wiring issue then, a poor connection, maybe an earth?
