moneypit23
Brake lights
I pulled up at home the other day and a bloke told me my driver's side brake light was out, it was so i changed it. Got the boyfriend to check the new one was working which it was/is but now when i brake the driver side headlight comes on as well.
Has anyone got any idea what i've done, taxis keep pulling out in front of me because they think i'm flashing them.
Thanks, Kate
Wrong bulb?
Put wrong bulb into my brake light once and the fogs kept coming on every time I braked!
failing the bulb check all the wiring connections at the lamp and check the condition of the bulb holders as it could be possible for a dodgy connection to cause a back feed to the other lights ive seen it happen before , hope this helps :)
