MarkGolf
Oil cooler required bits?
Hi,
I've got a 13 row cooler and that is all..
I know I need a sandwich plate and hoses. I plan to pop down to think automotive this week and get myself these bits, but, is there anything else I need?
download.php?id=31602
What is the thing in the bag and can I bin the standard oil cooler?
I have no clue when it comes to the best set up for oil coolers so any advice is good advice!
Thanks
p.s, what length hose do I need?
i can supply you these parts all you need to is specify the length of hose needed and also what thread type on your cooler. Std is 1/2"bsp for referance
Not 100% sure on length as yet.. (Whats everyone else had?)
Can I bin the standard oil cooler?
I'll be inclined to go with you :D
goin le man ths year?
MarkGolf, I'm in th esame position as you my man. I've got just the cooler and nothing else. I'd be interested in your comments g-man, Oh, and mines a VR with aircon so i'm a bit rtestricted on space.
I have a mocal cooler. 1/2" BSP fitting with 1 m of line all hooked up to a Mk1 Oilfilter mount. 1.5m of line should be fine. My cooler is mounted infront of the Rad.
I dumped the original oil water heat exchange unit. Still got it in the shed. Will refit if it is needed.
2_Door_fun, do you have the sandwich plate and thermostat setup or is the mocal permanantly in circuit regardless of oil temp?
