junkie 0 Posted May 20, 2006 Cheers Henny thats really helpful. So i thought a had a early set been a 91 H but appears not the case as i have the two LCD's. Certainly sounds alot easier and probably a whole lot more reliable to get them reprogrammed. Will have to investigate some more now, cheers henny thought i had come to a conclusion over it all. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 20, 2006 All G60s had the digital odometer. A '91 'H' should have the earlier of the two G60 clock internals. That makes it easier for you. I'd like to get a set of each clock type because I really can't see this being a big deal. Quote Share this post Link to post Share on other sites
Riley 0 Posted May 20, 2006 hows about late 2.0 16v clocks ian/henny? sorry,may have missed something earlier in the thread... Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 20, 2006 I don't think the 2.0 16v rev counter is scaled to 8k RPM. I think that's only found on the 1.8 16v. Quote Share this post Link to post Share on other sites
junkie 0 Posted May 20, 2006 bcstudent said: All G60s had the digital odometer. A '91 'H' should have the earlier of the two G60 clock internals. That makes it easier for you. I'd like to get a set of each clock type because I really can't see this being a big deal. Well thats what i thought as it should be just before the change over date. The early G60 clocks and the early valvers should be the same and as you say should be no big deal. Quote Share this post Link to post Share on other sites
Henny 0 Posted May 20, 2006 bcstudent, nope, not all G60s had the double LCD ones... the very first ones had the mechanical odometer, as did the early LHD ones... They're rare in RHD, but they do exist. Riley, Late 16V clocks don't have the redline to 8K as bcstudent says... 8) Quote Share this post Link to post Share on other sites
Riley 0 Posted May 21, 2006 are these the type of clocks needed then guys? 2x lcd displays,and sat in an 1800cc valver? neil. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 21, 2006 Henny said: bcstudent, nope, not all G60s had the double LCD ones... the very first ones had the mechanical odometer, as did the early LHD ones... They're rare in RHD, but they do exist. Oh, ok. Hands up who's got an original G60 with a mechanical odometer clock-set. Quote Share this post Link to post Share on other sites
junkie 0 Posted May 21, 2006 Riley said: are these the type of clocks needed then guys? 2x lcd displays,and sat in an 1800cc valver? neil. So we saying then in some valvers they have the 2 lcd's and its out of one of thosr that i need the rev gauge. As i already understand it this is the case and should swap over relatively easy. Quote Share this post Link to post Share on other sites
Henny 0 Posted May 23, 2006 ooh, I've never come across a 1.8 valver with 2 LCDs... :crazyeyes: Wonder if that's original?!? :| Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 23, 2006 I haven't seen that before either. The plot thickens further! Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 30, 2006 thats what ive got in mine, 2 lcd`s on 1.8 16v Quote Share this post Link to post Share on other sites
junkie 0 Posted May 30, 2006 ben16v said: thats what ive got in mine, 2 lcd`s on 1.8 16v And the rev gauge is 8k? Quote Share this post Link to post Share on other sites
Henny 0 Posted June 8, 2006 iiiiinnnntttterrrreessstttiiinnngggg.... Quote Share this post Link to post Share on other sites
ben16v 0 Posted June 8, 2006 just to continue.. i`ve got an old 1.8 16v set of gauges here with the analogue display and its got different fittings on the back than my 2 lcd one mine has 1 rectangular black socket and a vacuum pipe older one has white rectangular socket, 1 vacuum pipe and another round - what looks like mechanical fixing on the back Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 8, 2006 Quote what looks like mechanical fixing on the back That'll be the speedo drive then? Quote Share this post Link to post Share on other sites
ben16v 0 Posted June 8, 2006 bcstudent said: Quote what looks like mechanical fixing on the back That'll be the speedo drive then? yeah its in the midddle behind the speedo so your right was just pointing it out Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 9, 2006 I like the idea of getting rid of the cable speedo drive. It makes removing the clocks way more of a pain! Quote Share this post Link to post Share on other sites
junkie 0 Posted June 11, 2006 So basically then i can fit an 8K rev gauge from the apparently rare 2 lcd 16V clocks. Happy hunting for me then? Quote Share this post Link to post Share on other sites
ben16v 0 Posted June 11, 2006 i`m sur supercharged junkie dubprince has one for sale edit!!! http://the-corrado.net/.archive/forum/viewtopic.php?t=43074 edit seen you posted already ben Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 12, 2006 I'm sure the rev counter in both types of clocks is going to be the same. Quote Share this post Link to post Share on other sites
junkie 0 Posted June 15, 2006 So even if the rev gauge is the same in both sets of clocks if i just swapped over the whole unit as pictured above with the 2 lcd screens but 8 k will all work as normal. As described above with the connections are they the same as what would be on mine been a G60? Quote Share this post Link to post Share on other sites
bcstudent 0 Posted June 15, 2006 IHIG60 said: So even if the rev gauge is the same in both sets of clocks if i just swapped over the whole unit as pictured above with the 2 lcd screens but 8 k will all work as normal. As described above with the connections are they the same as what would be on mine been a G60? It's getting a bit late to be thinking too hard, but I'd say 'yes, the rev counter should work'. Isn't there a difference between the 16v and G60 vacuum sender on the back of the clocks though? Your MFA may not work properly if you swap the clocks complete. Quote Share this post Link to post Share on other sites
Henny 0 Posted June 16, 2006 you'd have to open up the cluster and swap over just the rev counter, although it still may just be the firmware in the cluster that allows for the 8K redline, the mechanism may use the same electronics and coils to make it work... :| Quote Share this post Link to post Share on other sites
