heliosjim
Mot Time-Wish me luck!
0930 hours tomorrow, booked the beast in, Im sure it will fail on the brakes as the discs have seen better days, passenger door handle and hazard warning light is being a pig!
Hopefully nowt else, not had time to fit the new brakes yet as im on holiday and the wife has been beasting me around the house with the roller and laminate.......need to go back to work for a rest!!!!!!!!!!!!!
Update around 1000 hours
Good luck... if you're so sure it'll fail on those bits wouldn't it be a good idea to get them done before the test?
Not had the time mate, the garage im taking it to are very reasonably priced so may get them to do the work, still waiting on the door handle to arrive.....
As long as the brakes pass the performance test, and the discs aren't paper thin, you'll only get an advisory. At least you should only get an advisory.
The rest of it....well, you're screwed with that :)
