Crispo 0 Posted May 25, 2006 My G60 seems to take a long time to heat up after starting and I just wanted to check if this is normal? I've tried searching for an answer and had no luck - most posts are concerning running too hot not too cold so maybe I should consider myself lucky. After starting I drive the car straight away but keep under 3000rpm until the oil is up to 90. This can take over 10 mins which seems like a long time - also the water temp gauge seems to take an age before it even rises off the stop. Hope someone out there can help. Cheers Quote Share this post Link to post Share on other sites
markp 0 Posted May 25, 2006 10 minutes to get the oil up to 90 sounds about right. Although the water temp shouldn't take that long to move. It could be that the temp sender switch is on it's way out (just a guess). It's not expensive to replace. Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 25, 2006 has it got an after market oil cooler fitted? i reckon as long as the oil does get up to temp your ok Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted May 25, 2006 sounds right based on my 16v too (well between 7-10 depends on the temp really) Quote Share this post Link to post Share on other sites
Crispo 0 Posted May 25, 2006 Thanks for the replies. I haven't got an aftermarket oil cooler fitted and the oil temp does go up. As far as the water goes it does seem to take a long time to go up - and on some shorter journeys won't even rise as far as where the numbers start. The guage does work though as proved when stuck in traffic when it's pointing to the sky and the fans going for all it's worth! Not driven another corrado but compared to other cars I've driven seems to take an unusually long time to heat up. How can I check if the temp sensors are working correctly? Cheers C. Quote Share this post Link to post Share on other sites
ben16v 0 Posted May 25, 2006 sound ok then buddy, just get up earlier and take the long route to work.... Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 25, 2006 Could your thermostat be stuck open? That'd cause a slower warm-up too. It's also cheap and easy to replace. Quote Share this post Link to post Share on other sites
Crispo 0 Posted May 25, 2006 How would I know if my thermostat was stuck open? And what would that mean? As I'm sure you may well have guessed I'm not the most technical of people - but I like the sound of cheap and easy to replace! Cheers C. Quote Share this post Link to post Share on other sites
bcstudent 0 Posted May 25, 2006 It would mean that the coolant is being flowed through the radiator from start-up, rather than being diverted through the engine only. The thermostat should initially be closed, which allows the engine to reach proper operating temperature quickly before it opens to prevent overheating. Quote Share this post Link to post Share on other sites
G60-R 0 Posted May 25, 2006 If you want to check if a thermostat is working ok take it out and drop in to a cup of boiling water. it should open if it's ok. if not, new one. Quote Share this post Link to post Share on other sites
G60SC_Stoney 0 Posted May 26, 2006 thermostat. check my post!! fixed it on wednesday. mine was stuck closed tho, causing a watery volcano!! Quote Share this post Link to post Share on other sites
