Riley
G60 brakes onto vento?
Whats involved here?
G60 brakes onto a 4 stud vento?
am i right in thinking that the vento (tdi btw) is on 239 set up? so therefor needs the G60 hubs as well as the obvious calipers?
anything else?
cheers,neil. :)
ok,just had a look about and seems that the vento could either have 239's or 256's...
if 256's its just a case of bolting up the G60 carrier and caliper i think?
just found out the vento is a 98 model also.
cheers,neil.
bump for the above.
plus,anyone got a good idea what a full front g60 brake set up is worth?
and how much would be fair to charge a mate of a mate for fitting it?
could do with some idea's before tommorow!
neil.
hello mate, im not really to sure but i would say that if it was a 256 you should be fine, they just use gold mk3 parts right?
(bump :D )
