OSV 0 Posted June 29, 2006 Retro fit HID Zenon lighting, has anyone used this product or heard reviews. Seems quite interesting, potential for a group buy perhaps if its as good as it sounds. http://www.hids4u.co.uk/default.asp Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 29, 2006 got their H1 kit in my 993............simple to fit and looks factory........the only prob might be the legality of them on the C but then again its only new cars that have to have the automatic leveling and H/L wash.....i thought i'd chance it with my 993 as its got H/L washers and manual(from in the cabin) headlight adjustment Quote Share this post Link to post Share on other sites
dub envy 0 Posted June 29, 2006 I know that a couple of the polo boys are running hids4u kits.. they seem to be pretty happy. As for starting a group buy, yeah I'm up for a set. Try Martin at http://www.vagparts.com for prices too as he sells kits. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 29, 2006 ..............and the performance is night and day btw Quote Share this post Link to post Share on other sites
Andy665 0 Posted June 29, 2006 There are absolutely no issues re: MOT, all the tester checks is alignment, it is a requirement for OE HID's to have high pressure washing and automatic level adjustment but this is not a requirement for aftermarket fitment. I have HID's in my Nugget and they are awesome, just white light, only downside is it makes main beam totally redundant now because the output is so much worse Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 29, 2006 and of course you get the peeps who think your on main beam when your not Quote Share this post Link to post Share on other sites
flusted 0 Posted June 29, 2006 im up for group buy Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 29, 2006 Can't you get HID main beams then? Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 29, 2006 Can't you get HID main beams then? think they are illegal not to mention blinding!!! :shock: Quote Share this post Link to post Share on other sites
Andy665 0 Posted June 29, 2006 I think you can but in effect they are same output as dipped beam so you're just doubling up on the total output Quote Share this post Link to post Share on other sites
woody 0 Posted June 29, 2006 Yep i have the same kit as Andy665 and the light output is such an improvement. Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 29, 2006 Gareth do a group buy mate. i be in for some of this Quote Share this post Link to post Share on other sites
sciroccotune 0 Posted June 29, 2006 what kind of price are we talking here>? Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 29, 2006 Ok time to put a few myths to bed on HIDs I looked into fitting them to my Leon but some help from a family member that works for the DVLA and a few boffins at an atuomotive testing facility. (basically the test stuff like this) Basically from the legislation we could work the following out. however this is enterpritation, and not legally checked. You can fit them legally however You must use the correct E marked equipment you must use headlamp housing designed to take the bulb, (you cannot modify non HID housings as they then loose the E mark) The lenses must also conform to type approval for that headlamp type. So in a nut shell for example Retro fitting them for a standard corrado headlamp housing, is illegal modified or not. Retro fitting them to an aftermaket headlamp housing E marked for that type of device is legal. An Example I could have a MK4 golf with standard type headlamps, buy a HID kit and OEM or aftermarket HID housings and fit them to a mk4 golf. You dont need washers or autoleveling....but they do have to be electrically adjustable. Bascially with the case of my Leon, I found the aftermarket lenses, and the KIT, but the headlamps housings had to no level adjustment. so made them illegal. Quote Share this post Link to post Share on other sites
OSV 0 Posted June 29, 2006 ah, but are they much brighter Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted June 29, 2006 im not too bothered about legality. id be interested in a group buy price, unless this causes the forum a problem through promoting etc.. Quote Share this post Link to post Share on other sites
Furkz 0 Posted June 29, 2006 Ok time to put a few myths to bed on HIDs I looked into fitting them to my Leon but some help from a family member that works for the DVLA and a few boffins at an atuomotive testing facility. (basically the test stuff like this) Basically from the legislation we could work the following out. however this is enterpritation, and not legally checked. You can fit them legally however You must use the correct E marked equipment you must use headlamp housing designed to take the bulb, (you cannot modify non HID housings as they then loose the E mark) The lenses must also conform to type approval for that headlamp type. So in a nut shell for example Retro fitting them for a standard corrado headlamp housing, is illegal modified or not. Retro fitting them to an aftermaket headlamp housing E marked for that type of device is legal. An Example I could have a MK4 golf with standard type headlamps, buy a HID kit and OEM or aftermarket HID housings and fit them to a mk4 golf. You dont need washers or autoleveling....but they do have to be electrically adjustable. Bascially with the case of my Leon, I found the aftermarket lenses, and the KIT, but the headlamps housings had to no level adjustment. so made them illegal. none of the MOT places iu even been, check stuff like that tbh Quote Share this post Link to post Share on other sites
G60Jet 1 Posted June 30, 2006 It not an MOT issue as i found out. The mot is a road worthness and is only a basic check to which even the DVLA admit. Basically cars go on the road after being Type approved for the eqipement fitted to them. Any kit fit after must conform to the laws of the land. there is no check for light equipment type on the mot test. purely that it works. The problems comes if you get stopped by the police or you have a crush and they find the kit fitted illegally. Plus Insurance issues. Not something id be willing to open up. Okay you might loose your own car as they wont pay out in a crash...but could you afford to pay for the other persons looses and medical bills? worst case i know, but it about being responsible on the roads these days. Quote Share this post Link to post Share on other sites
flusted 0 Posted June 30, 2006 Arent you covered 3rd party no matter what,as long as you have insurance? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted June 30, 2006 I think you can but in effect they are same output as dipped beam so you're just doubling up on the total output OK cheers. Like you found, I'm not sure I like the idea of switching the beams on only to find they are dimmer than the dipped beams! Don't mind if the mains are the same output, just so long as the light is all white, and not a mixture of candle power and HID. Quote Share this post Link to post Share on other sites
OSV 0 Posted June 30, 2006 From the website This kit is true bixenon and gives you both low beam and main beam in HID xenon. The bulbs have shields at the bottom and end caps to prevent glare on even the latest clear headlamps including Freelanders, Skoda Octavia, Fabia and Subaru and all other H4 applications This kit has perfect beam patterns, just check out the image for the left 6000k low beam light on my own car. No glare is produced due to the specail design of the shield and cap. Many people worry about the delay between low and high beam, but i can assure you the swtich from low to high is instant. Also you can flash the main beam from cold, and its bright and affective. We have sold hundreds of these kits and only had 2 faulty solenoids - unlike more expensive kits we tested where failure rates were upto 30%!! Quote Share this post Link to post Share on other sites
Storm Monkey 0 Posted June 30, 2006 Not sure about there use in cars, but in other uses (e.g. dive lights) HID lamps can take a few mins to warm up to full brightness, and there life is governed by the amount of times they are turned on and off, not hours on service. Minor points I know, but worth considering. IIRC, replacement bulbs are bl**dy expensive too! very bright high temp output and low power consumption though! Phil Quote Share this post Link to post Share on other sites
vr6storm 0 Posted June 30, 2006 the ones i rerto fitted only take seconds to get to full brightness,compared to factory fitted ones my father-in-law has in his RR its only slower by 1-2 secs Quote Share this post Link to post Share on other sites
Guest Posted July 1, 2006 If a Group Buy gets sorted I'm in :) Quote Share this post Link to post Share on other sites
