big_chris1981 0 Posted July 6, 2006 ive got my beady little eye on some new recaros....but it would seam that recaro dont make a subframe for the corrado. anyone got any sensible suggestions? (using a nail gun/chewing gum/bolting them to the floor or wedging them in with a bit of wood dont counmt as sensible ;)) Quote Share this post Link to post Share on other sites
Phil K 0 Posted July 6, 2006 AFAIK you'll have problems getting them to sit low enough... not to say it isn't possible but you may need some doner seats to chop up for the sub frames :? Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 6, 2006 hmmmm...interesting. from what i can work out they used to list corrado frames....but they dissapear off the list sometime in 1997. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 6, 2006 But the recaro frames still sit too high. Get a cheap set of C seats if you can and rob the subframes off them and adapt them Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 6, 2006 sounds like a plan....would need a whole late interior anyway as id want to sell my leather on rather than butcher it/retrim. shall consult the wallet faries..... Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted July 6, 2006 Your only plug and play option is to take the subframe from a set of corrado recaros.. rare and expencive. good luck with the butchering! Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 6, 2006 i didnt think corrado recaros had bolt on subframes? thought they were welded? happy to be corrected.... Quote Share this post Link to post Share on other sites
A20 LEE 0 Posted July 6, 2006 i didnt think corrado recaros had bolt on subframes? thought they were welded? happy to be corrected.... corrado or scirocco recaro subframes allow a straight bolt in fit of the vast majority of recaro seats. Check the pic in my sig!! Quote Share this post Link to post Share on other sites
andyVR6 0 Posted July 6, 2006 might be a daft question but are the subframes for golfs and polos the same as the corrados, i know they look identical but not sure on dimensions. would have thought that they would do subframes for a golf. Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 6, 2006 the golf and polo ones are a differnt angle. i shall be keeping an eye out for a recaro interior then lee ;) Quote Share this post Link to post Share on other sites
yalan 0 Posted July 6, 2006 go for butchery! much more fun! Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 18, 2006 this is the etka image for a corrado recaro seat.....im i right in thinking that number 3, the seat frame, is all you would need to bolt a more current recaro seat to? Quote Share this post Link to post Share on other sites
big_chris1981 0 Posted July 18, 2006 forget that....£695 each plus vat. Quote Share this post Link to post Share on other sites
Stone0311 0 Posted January 17, 2007 yalan im bout to attack the same affair as you have. Any major hints/tips on creating a subframe? Quote Share this post Link to post Share on other sites
KADVR6 0 Posted January 19, 2007 i bought some freshly trimmed recaro's last week, knew i could not get recaro subframes. so got 2 corrado seat bases, and simply welded them onto the bottoms of the recaros :) i still have the usual corrado seat adjustment, plus i'm 6ft 2" and i still have enough head room, so all you short people will be fine. Quote Share this post Link to post Share on other sites
TomD 0 Posted January 20, 2007 i bought some freshly trimmed recaro's last week, knew i could not get recaro subframes. so got 2 corrado seat bases, and simply welded them onto the bottoms of the recaros :) i still have the usual corrado seat adjustment, plus i'm 6ft 2" and i still have enough head room, so all you short people will be fine. i was half way through doing this with 2 RS turbo Recaros for my golf, but then I sold it before i'd finished. They're sitting in the garage as I assumed that they'd sit too high for the rado They're on Scirocco subframes...do they sit at the same height as rado ones? Might have to finish them off! :) Quote Share this post Link to post Share on other sites
yalan 0 Posted February 4, 2007 yalan im bout to attack the same affair as you have. Any major hints/tips on creating a subframe? yeah: 1) if the 3 mounting points have to be separated, tack in a temporary framework to keep everything lined up and true. Chop it out again when all is in place. 2) don't forget about the seat sag underneath - you might be able to get the seat itself lower, but with the persons weight on top you don't want to find you're sitting on the sliding lever squeezing up through the foam between your butt cheeks! Quote Share this post Link to post Share on other sites
Stone0311 0 Posted February 5, 2007 Cheers bud. 2) don't forget about the seat sag underneath - you might be able to get the seat itself lower, but with the persons weight on top you don't want to find you're sitting on the sliding lever squeezing up through the foam between your butt cheeks! :thumbleft: :lol: Quote Share this post Link to post Share on other sites
vwgti 0 Posted February 13, 2007 i bought some freshly trimmed recaro's last week, knew i could not get recaro subframes. so got 2 corrado seat bases, and simply welded them onto the bottoms of the recaros :) i still have the usual corrado seat adjustment, plus i'm 6ft 2" and i still have enough head room, so all you short people will be fine. just a question I have a set of MK3 Recaros can I just transfer the foam over from the reacros into the rado original seat bases or I need to transfer the entire seat base? thanks in advance. Quote Share this post Link to post Share on other sites
KieranM 0 Posted February 13, 2007 sounds like a plan....would need a whole late interior anyway as id want to sell my leather on rather than butcher it/retrim. shall consult the wallet faries..... Well i've got a late interior thats not leather if you fancy a px?! 8) Quote Share this post Link to post Share on other sites
