craziscot 0 Posted July 31, 2006 Ok, I have tried the search and can't find anthing similar...... When I press the button for the drivers side window it goes half up, then if I press it again it slowly goes up to close, its been working fine up til yesterday, only noticed it because the total closure on the alarm only put the window up half way, then when I press the button it went up the rest of the way. Is there a limit switch or something?? Any Ideas anyone? Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted July 31, 2006 Is a rattle when you shut the door? Quote Share this post Link to post Share on other sites
craziscot 0 Posted July 31, 2006 The windows on both sides rattle a bit, if they are down, when you shut the doors, more so on the passenger side though.... Quote Share this post Link to post Share on other sites
Mr Sands 0 Posted July 31, 2006 I have developed a similar problem recently on the VR, exactly the same symptoms. Sometimes the window goes up all the way on the switch or when turning the key in the lock, but other times it stops halfway and requires the switch to be released and pressed again. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted August 4, 2006 Are the rivets still there? Take the door card off and make sure nothing is getting caught. Quote Share this post Link to post Share on other sites
