Storm_VR6 0 Posted August 4, 2006 At the usual 55 – 60 mph speed, I noticed that the active spoiler started to rise but then stopped short of a full erection. Put my foot down a bit more to see if this would make any difference but no luck….. Went out in a friends VR the other day and noticed that the spoiler raises fully at the set speeds... Any ideas? - I've thought about adding some viagra in my fuel tank but doubt that would help. Help & advice would be much appreciated. Quote Share this post Link to post Share on other sites
Supercharged 2 Posted August 4, 2006 Pornography? Quote Share this post Link to post Share on other sites
chrishill 0 Posted August 4, 2006 viagra in the form of white grease spraied onto the motor and the spoiler struts should see you being able to sustain a full and satisfying erection. If not, try pushing it up manually by getting in behind it and see if you can get it up further by hand as opposed to letting it come up on its own. Quote Share this post Link to post Share on other sites
M15 VW 0 Posted August 4, 2006 Is it getting caught on anything? have you tried lubing it up? :lol: :oops: Quote Share this post Link to post Share on other sites
DUB 0 Posted August 4, 2006 Or just plane old yanking it Bristol fasion :lol: Quote Share this post Link to post Share on other sites
Bally 0 Posted August 4, 2006 LMFAO!! think you need a trip away lol Quote Share this post Link to post Share on other sites
chrishill 0 Posted August 4, 2006 I'm trying desperatly to remember the website from the 'are you or your partner one of the millions of men that experiances and erection problem?' advert... god damn my forgetful brain! Quote Share this post Link to post Share on other sites
Mave 0 Posted August 4, 2006 chrishill said: I'm trying desperatly to remember the website from the 'are you or your partner one of the millions of men that experiances and erection problem?' advert... god damn my forgetful brain! That was Pele wasn't it? Hmm, try rubbing a PVW mag over it.. Quote Share this post Link to post Share on other sites
Storm_VR6 0 Posted August 4, 2006 When using the manual button, I can achieve full erection....with the manual button, i press it, it goes up a little then stops, press it again, a little higher...after 3 or 4 pushes, it's fully erected....is this how it's meant to work ? It was working fine before....WTF has happened to it? Quote Share this post Link to post Share on other sites
gaz1000 0 Posted August 4, 2006 ive got similar prob manually its ok but when i brake the speed limit it wont move. Quote Share this post Link to post Share on other sites
mtc R32 0 Posted August 4, 2006 Try shocking it.... Maybe going in at the rear... With a little fidling around you just over come your problem..... Haven't got a clue with your spoiler!!!! I'm thankfull everything works fine at my end...... :lol: Quote Share this post Link to post Share on other sites
Storm_VR6 0 Posted August 4, 2006 lol - MTC gaz1000 - After breaking the speed limit, my one does move, it gets to the semi stage then stops. chrishill - I'm gonna buy some Kamagra Jelly and rub it in the right places, I'll also have some PVW pics at hand... Seriously guys, any suggestions?? Quote Share this post Link to post Share on other sites
DUB 0 Posted August 4, 2006 Wip the inside back off, have a play with the hand opp tool {already in place} give plenty of lubrication - also lub the hydrolic ram's on the rear end - go out break the speed limit a couple of times and i think then Bob will be a relative of yours :lol: Quote Share this post Link to post Share on other sites
chrishill 0 Posted August 4, 2006 yup, silly as my suggestion reads, its actually accurate :) lube up the struts that lift the spoiler with white grease (not WD40 since it only works for a while and tends to get gritty) from the inside (remove panel on oposite side of reg plate, inside the boot) then lube up the motor and all moving parts. The only other thing i can think is that the motor is mis-aligned and thinks the spoilers fully up when its not? Quote Share this post Link to post Share on other sites
Storm_VR6 0 Posted August 4, 2006 chrishill - Thanks, will give that a try as soon as i get home from work. Is it okay to use silicon Maintenance spray? Quote Share this post Link to post Share on other sites
chrishill 0 Posted August 4, 2006 i really dont know mate, I'm not sure whats in it! I was told WD40 = bad and grease = good :) Quote Share this post Link to post Share on other sites
Dubby 0 Posted August 4, 2006 Tried fiddling with your button? :lol: Quote Share this post Link to post Share on other sites
Furkz 0 Posted August 4, 2006 have spoken to bally and he did advise me that he knows how to sort this problem out and he does have an ebay contact that can help with this problem but hes currently away in south america, bally also advised to pm him for his special products has he was too shy to post on here... website of tips and tricks coming soon Quote Share this post Link to post Share on other sites
Bally 0 Posted August 4, 2006 Quote have spoken to bally and he did advise me that he knows how to sort this problem out and he does have an ebay contact that can help with this problem but hes currently away in south america, bally also advised to pm him for his special products has he was too shy to post on here... website of tips and tricks coming soon Furks talking shi* again I see Quote Share this post Link to post Share on other sites
M15 VW 0 Posted August 4, 2006 Theres some sort of speed regulator for the spoiler but cant think where it is at the moment. Quote Share this post Link to post Share on other sites
Furkz 0 Posted August 4, 2006 Bally said: Quote have spoken to bally and he did advise me that he knows how to sort this problem out and he does have an ebay contact that can help with this problem but hes currently away in south america, bally also advised to pm him for his special products has he was too shy to post on here... website of tips and tricks coming soon Furks talking shi* again I see hehe, why u being soo shy for man just post the link here Quote Share this post Link to post Share on other sites
Bally 0 Posted August 4, 2006 bro, I post yr phat ass to another planet lund lol Quote Share this post Link to post Share on other sites
Furkz 0 Posted August 4, 2006 you overdosed on the medication then lol Quote Share this post Link to post Share on other sites
