billinjah
screen flicker
installing a ps2 and clarion screen today anyone know why the screen flickers so you cant see the picture? using a joytech car power adapter. it flickers whether car is off or on.
Same question then, what leads are you using? Are they separate phono leads or are you using a combined lead ie scart? See where Im going with this ;)
Sounds like an internal problem then mate. The amp inside may be knacked, or there may just be a loose connection inside. Whip the lid off and see if you can see anything, if not have a look for a repair place near you. They can normally stick it on a test bench and tell you straight off.
