Fenn
2.0l 8v wont rev past 4250 rpm???
ok my GF's new 2.0l 8v hits the limiter at 4250 rpm and feels really flat above 3.5k. its a 95 and the timing belt was changed before i bought it.
do you think it could be a tooth out?
any other surgestions would be apreciated!
thanks Rob
Try changing the HT leads, sparks too.
Possible that the timing belt skipped a few teeth too.
Had a similar problem with my 16V which turned out to be the Air Flow Meter... dunno if it's the same with yours but it's worth a thought!
