CorradoDriver 0 Posted August 19, 2006 Okay i just bought subs and an amp, now idk where to wire this stuff. I know i need to run a wire from the battery to the amp in the trunk but where do i do this from. The battery to inside the car. anyone know where i can feed the wire from, please help Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 19, 2006 You have to put your own wire in, i found a grommit in the passenger foot well that i pushed out and fed the wire throught that, down the side of the car under the sills that just pop out. run your speaker cables (RCA's) in a diferent route to your power cables as it'll cause interferience. Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 19, 2006 I know i have 2 run wires but i wasnt sure how to get the wires from the battery to inside the car Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 19, 2006 mine is a RHD, not sure what yours is, but if you go into the passenger foot well, pull the carpet down, you will see a plug/ grommit, push it and it'll pop out, run the wire through that. Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 19, 2006 Sounds good, im in the US so i have a left hand drive Corrado. i was planning on running power from driver side as my battery is located there and the audio from the passanger side. I will take a look 2 morrow for the Grommits Quote Share this post Link to post Share on other sites
-Neil- 0 Posted August 19, 2006 im not sure where if the grommits on my passenger side will be free on yours as your driving equipment is there for your peddles etc. Take a look, there might be a free hole (ooooh errrr!) Quote Share this post Link to post Share on other sites
andy 0 Posted August 19, 2006 Don't forget to fuse your amp supply mate, a lot of people don't bother. I was in a car when the amp supply shorted to the bodywork, the whole car filled with choking plastic fumes within seconds as the cable insulation burnt off! Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 19, 2006 yhea dont worry, i ordered an amp wiring kit from ebay, has all the stuff i need, fuse fuse holder 4 guage wires all the good stuff. Thanks HEY LOOK IV BECOME A CF ENTHUSIAST :D :) :shock: :onfire: 0X :roll: :D :) :icecream: :doc: :nurse: :onfire: :onfire: :multi: :snipersmile: :scatter: :afro: :salute: :salute: :hitler: :offtopic1: Quote Share this post Link to post Share on other sites
CorradoDriver 0 Posted August 19, 2006 dam is that hitler??? Quote Share this post Link to post Share on other sites
