corrado vr6 0 Posted September 6, 2006 Hi i asked a while ago about my drivers side wing mirror that had stopped working from left to right but still goes up and down i know that the motor for both operations are working as i can still hear it i have removed the mirror using a ruler (good tip!!) and i can understand how the up and down movement works by the use of a white notched arm that gets pulled in or pushed out to make the up and down movement of the mirror but i cant see how the motor reaches the mirror to make it go left or right so i have decided to post a picture as an attachment to see if any of you can tell me if there is anything missing as i would guess another notched arm must run through the center of the back of the mirror and be driven by the motor is this correct that it has snapped and fallen out. any clues much appriciated also if this is so can any of you tell me where i could get a replacemnt good places to buy from etc for these sorts of parts. thanks in advance Greg Share this post Link to post Share on other sites
Walesy 0 Posted September 6, 2006 http://the-corrado.net/.archive/forum/viewtopic. ... ht=#549652 Share this post Link to post Share on other sites
