boy bernard 0 Posted September 21, 2006 The driver side rear arch on my car has taken a bit of a smack. bit to much to hit with the filler so want to get a new arch welded in place. Can I use the arch from the front wing? If not how easy is it to source rear repair sections? Cheers B Quote Share this post Link to post Share on other sites
dinkus 10 Posted September 21, 2006 You can get replacement panels for the Corrado, but the whole rear quarter is one piece. It sound slightly silly, but it'll almost certainly be easier for a bodyshop to fit a whole new panel rather than try and weld a new arch on and get it to look right. You can probably find someone on here that's willing to cut a rear quarter off an old scrapper. Alternatively, it may be possible for of those paintless dent removal guys to get it out, but that would very much depend on where exactly it is, how big it is and what the guy reckons he can fix. Quote Share this post Link to post Share on other sites
RS VR6 0 Posted September 21, 2006 I got a quote from a bodyshop for 700usd for a rear quarter panel. I'm sure you can use a front arch...but the porportions are not correct. Just find a wrecked Corrado and get the entire rear quarter from it. When I got rear ended the, part below my taillights was completely smashed in. I found a wrecked Corrado and cut that piece out, and gave it to the bodyshop to weld in. The part where the "RS" badge is, to the middle of the license plate is from another car. Quote Share this post Link to post Share on other sites
gsbellew 0 Posted September 21, 2006 If you get some pictures up it'd be easier to give an opinion, a rear 1/4 is a fair big job to fit right, you'd be amazed what a good panel beater could do. Quote Share this post Link to post Share on other sites
quicky1980 0 Posted September 22, 2006 Im still after the passengers side rear quater, and thats after 2 weeks of searchin on here Quote Share this post Link to post Share on other sites
quicky1980 0 Posted September 22, 2006 Another thing are all rear arches the same for early and late rados? Quote Share this post Link to post Share on other sites
Phil K 0 Posted September 22, 2006 Another thing are all rear arches the same for early and late rados? I 'think' it's only the front arches that differ... Quote Share this post Link to post Share on other sites
corradostuff 0 Posted September 22, 2006 I've also heard that you can use a front arch to replace a rear one. Don't quote me on it but I think someone on here said you need to turn the front arch around so it goes on the rear backwards. I'd find out for sure first though! and as Phil K says the new and late shape front arches are different so not sure which one you'd want either. Quote Share this post Link to post Share on other sites
