_leon_
G60 alternator - what Amp?
What amp is the G60 alternator? 65A or 90A? I need a new one and want to be sure I'm getting the right one.... Thanks
generaly its 65 on non A/C cars and 90 on a A/C car...should have a little sticker on it saying what it is
if you can afford the 90a you might as well get it ...pick the sticker off and the dealer/gsf will take it in as exchange
I upgraded to a 90A alternator and found the battery didn't run down anywhere near as much as with my old 65A one (found it in a breakers for £40). I make a lot of short journeys, so I've found the upgrade really useful.
never get the battery running down on me tbh - the bosche battery seemed to have solved that issue - car hasnt been ran for over 3 weeks and theres still plenty of life in it. just got an exchange on a 65a one from vag a week ago and today when placing another order i was told the correct one is 90a - hence the confusion!
don't think the 90a one is really required - i run no stereo equipment so...
If you use the 90amp alternater,best bet is to go for the 90amp battery too.
Nice little upgrade charging wise 8)
Neil.
  Supercharged said:
Make sure you get the right one tho as they won't take the 65A as an exchange for a 90A - I think the surcharge is £50 too!!
chances they will accept it..make sure the sticker gets a wipe with thinners, ive done it a few times and never been challenged
and yeah...my golf used to run the battery down with short trips, its alot better on a 90a one
